11 years agosoc_system_board_info.xml/hps_common_board_info.xml common accross most devboards ?
I'm using De0-nano-soc & De1-soc from Terasic .. neither has soc_system_board_info.xml & hps_common_board_info.xml included in the packages that arrived & Terasic is claiming their linux s...
11 years ago --- Quote Start --- really are living in minimal documentation land here ... (or there is too much & difficult to filter ...) --- Quote End --- Yes, I've found there to be a lot of documentation, but most of it is not well written. For example, "How do you create pin assignments for the HPS pins?" would be an obvious question to someone familiar with FPGAs. Its not obvious that the HPS pin assignments are a result of pin settings in the component instance (and are configured by the preloader). I'm not sure whether I have ever seen it stated in an Altera doc, I think I made that realization while watching a tutorial. --- Quote Start --- ... with any luck - be booting soon... (tonight ??!?) --- Quote End --- Good luck! Cheers, Dave
