9 years agoSlow memcpy speed
Hi all, I have a design based upon the “Lab 4 - Linux FFT Application” from Rocketboard which runs on the Terasic DE0-Nano-SoC (Cyclone V SoC) evaluation board. First the data is transferred ...
9 years agoI think my problem is related to the high address (ALT_LWFPGASLVS_OFST = ff200000) that is used, and this might have to be fixed in the kernel space…
While waiting for someone to fix this for me :) , I wrote an assembly version of the memcpy using the “NEON memory copy with preload” example from arm infocenter. I had to add “SUBS r2,r2,#0x40” before the loop, if not the loop would go 64 bytes too far (thus overwriting memory). Using this "neon memcpy" I got a bit more speed (62 MBytes/s), and I could use the -Ofast flag to optimize the rest of the code. This function is called the same way as memcpy, but the data must be 64 bytes aligned: void *neon_memcpy(void *ut, const void *in, size_t n) neon_memcpy.S: .arch armv7-a .fpu neon .global neon_memcpy .type neon_memcpy, %function neon_memcpy: SUBS r2,r2,#0x40 neon_copy_loop: PLD [r1,# 0xC0] VLDM r1!,{d0-d7} VSTM r0!,{d0-d7} SUBS r2,r2,#0x40 BGE neon_copy_loop bx lr
