9 years agoSlow memcpy speed
Hi all, I have a design based upon the “Lab 4 - Linux FFT Application” from Rocketboard which runs on the Terasic DE0-Nano-SoC (Cyclone V SoC) evaluation board. First the data is transferred ...
9 years agoAn update:
When defining arrays like this int value[2048]; //source array int dest[2048] ; //destination array and running memcpy(dest,value,2048*4), memcpy speed is high: 446 Mbytes/s And the compile flag -Ofast give faster speed than -O1, as expected. - - - - - - My design is based upon the fpga_fft example from Rocketboard where DMA transfers data from FPGA into HPS’s DRAM memory. The memory space for these data (*value) is defined using mmap: volatile unsigned int *value; volatile unsigned int dest[2048*4]; # define result_base (FFT_SUB_DATA_BASE + (int)mappedbase +(FFT_SUB_DATA_SPAN/2)) - - - - - - In main: // we need to get a pointer to the LW_BRIDGE from the softwares point of view. // need to open a file. /* Open /dev/mem */ if ((mem = open("/dev/mem", O_RDWR | O_SYNC)) == -1) fprintf(stderr, "Cannot open /dev/mem\n"), exit(1); // now map it into lw bridge space: mappedbase = mmap(0, 0x1f0000, prot_read | prot_write, map_shared, mem, alt_lwfpgaslvs_ofst); if (mappedBase == (void *)-1) { printf("Memory map failed. error %i\n", (int)mappedBase); perror("mmap"); } Run DMA and wait for completion ... ... // And when the DMA is finnished the data is available: value = (unsigned int *)((int)result_base); - - - - - - Now, when running memcpy(dest,value,2048*4) the speed is slow: only 42 Mbytes/s, and the compiler does not respond as expected to the -O compiler flags, i.e. -Ofast is slower that -O1. It seems that using mmap really slows down the access to memory. Is it possible to speed this up? Any help would be greatly appreciated! Thanks,
