12 years agoShare variables between verilog file and niosII application file(.c file)
Hello, I am trying to do a small concept where in I have created a project on DE2-115 board. In the same project, I have also implemented niosII processor and written a simple program to toggle th...
12 years agoOk... No issues
Anyways i will continue the activity of memory mapped slave with onchip memory and atleast make sure that i can access same onchip memory address locations via HDL and NiosII. if you can kindly confirm my assumptions of earlier post. and please have a look at my implementations below. the HDL code is getting compiled, but niosIi code is giving error. Kindly help.. HDL part module DE2_115_GOLDEN_TOP( .... // signals to connect to an Avalon-MM slave interface slave_address, slave_read, slave_write, slave_readdata, slave_writedata, slave_byteenable, // signals to connect to custom user logic (up to 16 input and output pairs) user_dataout_0, user_datain_0, // optional signals so that your external logic knows what location is being accessed user_chipselect, user_byteenable, user_write, user_read ); //======================================================= // PARAMETER declarations //======================================================= parameter DATA_WIDTH = 16; // word size of each input and output register parameter ENABLE_SYNC_SIGNALS = 0; // only used by the component .tcl file, 1 to expose user_chipselect/write/read, 0 to stub them parameter MODE_0 = 2; // 0 = Output, 1 = Input, 2 = Ouput and Input, 3 = Output with loopback, 4 = Disabled ---------------------------------------------------------- // slave interface input [3:0] slave_address; input slave_read; input slave_write; output reg [DATA_WIDTH-1:0] slave_readdata; input [DATA_WIDTH-1:0] slave_writedata; input [(DATA_WIDTH/8)-1:0] slave_byteenable; // user interface output wire [DATA_WIDTH-1:0] user_dataout_0; input [DATA_WIDTH-1:0] user_datain_0; output wire [15:0] user_chipselect; output wire [(DATA_WIDTH/8)-1:0] user_byteenable; output wire user_write; output wire user_read; *** reg [data_width-1:0] ram[10]; assign user_write = slave_write; // outputs are registed so need a delayed copy of the write signal assign user_read = slave_read; // using Qsys i had integrated niosII, PIO lEd, on chip memory and Avalon MM slave niosII_Qsys inst_niosII_Qsys ( .clk_clk (CLOCK_50), // clk.clk .redled_external_connection_export (LEDG), // redled_external_connection.export .amm_slave_ui_dataout_0 (slave_writedata), // amm_slave_ui.dataout_0 .amm_slave_ui_datain_0 (slave_readdata) // .datain_0 ); // finally ----------------------------------------------------------------------------- always @(posedge CLOCK_50) begin swreg = SW; if(swreg[0] == 1) begin flag = 1; regledr[0] = 1; end else begin flag = 0; regledr[0] = 0; end // write to memory only once when sw is turned ON if(flag == 1) begin flag = 2; // onchip memory address range starts at 0x20000, // i have directly written data 5 to the first array index. i don't know at which onchip address the ram variable starts. ram[0] <= 5; /*if(slave_write) ram[slave_address] <= slave_writedata; else if (slave_read) slave_readdata <= ram[slave_address]; */ end end NiosII code //Auto generated code# define ONCHIP_MEMORY2_BASE 0x20000 // ONCHIP_MEMORY2_BASE starts address main .c file variable = IORD((ONCHIP_MEMORY2_BASE+20), 0); In nios II when i try to read onchip memory address location (ONCHIP_MEMORY2_BASE + 20) using the above statement it gives me memory error as "address 0xaddf7c of niosII_SW.elf section `.bss' is not within region `onchip_memory2' ""address 0xaddf7c of niosII_SW.elf section `.onchip_memory2' is not within region `onchip_memory2'"
