SEVERE: Setting does not exist for BSP: "hal.linker.enable_exception_stack".
Did you try to create, edit and generate BSP using BSP editor and import as NIOS II software Build Tools project with the .sopcinfo file?
Thank you.
Kelly
- DemirSezer3 years ago
I tried your advice and it didn't work. This is what I get when I tried to crate BSP with .sopcinfo file,
However, when I try to generate the BSP with.sopcinfo file using the version 12.0, I achieved it but this didn't solve my problem since I can't generate the same .elf file which is generated before. Sizes of the .elf files don't match so I want to build project in 10.1 version. I observed that there is something wrong in linker section of version 10.1 and that is what I suspect to be the reason but couldn't solve it. These are the images from 10.1 and 12 respectively with same .sopcinfo file.
