14 years agoSet properties of VHDL package file from component TCL file
Hello, is it possible to change a value in a VHDL package file from a component TCL script? I have a component which is parameterized by a constant value which is set in a package: p...
14 years agoAh, yes, I have had to solve that one too ... the following is just typed in (so the VHDL syntax might be slightly wrong):
package simulation_pkg is
function simulation returns boolean;
end package simulation_pkg;
package simulation_pkg body is
function simulation returns boolean is
variable result := false;
begin
-- altera translate_off
result := true;
-- altera translate_on
return result;
end function;
end package simulation_pkg body ;
The other synthesis constraint that can be useful is -- synthesis read_comments_as_HDL on -- synthesis read_comments_as_HDL off Cheers, Dave
