15 years agoSerious Problem with DMA transfer.
Guys, I have a desperate problem on my hand. Using DMA to do burst transfers from DDR to on-chip RAM. Using the reference code as shown below. Searched all the forums and confirmed people using th...
15 years agoYour code footprint will change if you breath on it so instead of finding a spot that is not occupied I would do one of the following instead:
- Pre-allocate your buffer so that the compiler will not attempt to place anything there
- Dynamically allocate your buffer at run time
