guenniause
6 years agoSerial Flash Controller II - erase / program issue
On a customer board (Quartus Prime 18.1 / Cyclone 10 LP / W25Q64) I use the Serial Flash Controller II to access the serial flash W25Q64. Programming of the flash with JIC-file/Quartus-programmer an...
JohnT_Altera
6 years agoHi,
I would not recommend you to use Serial Flash Controller II to access W25Q64 flash as it is not validated to work on the flash. I would recommend you to use Generic Serial Flash Interface IP https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf.
