SDRAM NIOSV ash-riscv-gdb-server error
- 8 months ago
Hi ETang2
You could solve this error b increasing the OCRAM size in the Quartus project.
Once you do this you would need to regenerate the BSP again.
Hi, i confirm i'm trying to boot from OCRAM. I did the modification indicated and now i obtain a compilation error :
[proc] Exécution de la commande : C:\altera_standard\25.1std\riscfree\build_tools\cmake\bin\cmake.exe --version
[proc] Exécution de la commande : C:\altera_standard\25.1std\riscfree\build_tools\cmake\bin\cmake.exe -E capabilities
[kit] Chargement réussi de 2 kits à partir de C:\Users\tanguy-e\AppData\Local\CMakeTools\cmake-tools-kits.json
[variant] Chargement effectué du nouvel ensemble de variantes
[main] Configuration du projet : app
[proc] Exécution de la commande : C:\altera_standard\25.1std\riscfree\build_tools\cmake\bin\cmake.exe -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_C_COMPILER:FILEPATH=C:\altera_standard\25.1std\riscfree\toolchain\riscv32-unknown-elf\bin\riscv32-unknown-elf-gcc.exe -DCMAKE_CXX_COMPILER:FILEPATH=C:\altera_standard\25.1std\riscfree\toolchain\riscv32-unknown-elf\bin\riscv32-unknown-elf-g++.exe -DCMAKE_ASM_COMPILER:FILEPATH=C:\altera_standard\25.1std\riscfree\toolchain\riscv32-unknown-elf\bin\riscv32-unknown-elf-gcc.exe --no-warn-unused-cli -S C:/Users/tanguy-e/Downloads/test/software/app -B c:/Users/tanguy-e/Downloads/test/software/app/build -G "Unix Makefiles"
[cmake] Not searching for unused variables given on the command line.
[cmake] -- The C compiler identification is GNU 13.2.0
[cmake] -- The CXX compiler identification is GNU 13.2.0
[cmake] -- Detecting C compiler ABI info
[cmake] -- Detecting C compiler ABI info - done
[cmake] -- Check for working C compiler: C:/altera_standard/25.1std/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-gcc.exe - skipped
[cmake] -- Detecting C compile features
[cmake] -- Detecting C compile features - done
[cmake] -- Detecting CXX compiler ABI info
[cmake] -- Detecting CXX compiler ABI info - done
[cmake] -- Check for working CXX compiler: C:/altera_standard/25.1std/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-g++.exe - skipped
[cmake] -- Detecting CXX compile features
[cmake] -- Detecting CXX compile features - done
[cmake] -- The ASM compiler identification is GNU
[cmake] -- Found assembler: C:/altera_standard/25.1std/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-gcc.exe
[cmake] -- Configuring done (5.5s)
[cmake] -- Generating done (0.2s)
[cmake] -- Build files have been written to: C:/Users/tanguy-e/Downloads/test/software/app/build
[main] Génération du dossier : c:/Users/tanguy-e/Downloads/test/software/app/build
[build] Démarrage de la build
[proc] Exécution de la commande : chcp
[proc] Exécution de la commande : C:\altera_standard\25.1std\riscfree\build_tools\cmake\bin\cmake.exe --build c:/Users/tanguy-e/Downloads/test/software/app/build --config Debug --target all -j 8 --
[build] [ 1%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_ecc_exception_entry.S.obj
[build] [ 2%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_macro.S.obj
[build] [ 3%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_mcount.S.obj
[build] [ 4%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_vic_vector_table.S.obj
[build] [ 5%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_alarm_start.c.obj
[build] [ 6%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/machine_trap.S.obj
[build] [ 8%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_busy_sleep.c.obj
[build] [ 8%] Building ASM object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/crt0.S.obj
[build] [ 9%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_close.c.obj
[build] [ 10%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dcache_flush_all.c.obj
[build] [ 11%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dcache_flush_no_writeback.c.obj
[build] [ 13%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dev.c.obj
[build] [ 13%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dcache_flush.c.obj
[build] [ 14%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dev_llist_insert.c.obj
[build] [ 15%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dma_rxchan_open.c.obj
[build] [ 16%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_dma_txchan_open.c.obj
[build] [ 17%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_do_ctors.c.obj
[build] [ 18%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_ecc_error_inject.c.obj
[build] [ 19%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_do_dtors.c.obj
[build] [ 20%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_ecc_exception.c.obj
[build] [ 22%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_errno.c.obj
[build] [ 21%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_env_lock.c.obj
[build] [ 23%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_environ.c.obj
[build] [ 24%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_execve.c.obj
[build] [ 25%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_exit.c.obj
[build] [ 26%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fd_lock.c.obj
[build] [ 27%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fcntl.c.obj
[build] [ 28%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fd_unlock.c.obj
[build] [ 29%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_find_dev.c.obj
[build] [ 30%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_flash_dev.c.obj
[build] [ 31%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_find_file.c.obj
[build] [ 32%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fork.c.obj
[build] [ 33%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fs_reg.c.obj
[build] [ 34%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_fstat.c.obj
[build] [ 35%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_get_fd.c.obj
[build] [ 36%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_getchar.c.obj
[build] [ 37%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_getpid.c.obj
[build] [ 38%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_gettod.c.obj
[build] [ 39%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_gmon.c.obj
[build] [ 40%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_icache_flush.c.obj
[build] [ 41%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_icache_flush_all.c.obj
[build] [ 42%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_iic.c.obj
[build] [ 43%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_iic_isr_register.c.obj
[build] [ 44%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_instruction_exception_register.c.obj
[build] [ 45%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_io_redirect.c.obj
[build] [ 46%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_ioctl.c.obj
[build] [ 46%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_irq_handler.c.obj
[build] [ 47%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_isatty.c.obj
[build] [ 48%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_kill.c.obj
[build] [ 49%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_link.c.obj
[build] [ 50%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_load.c.obj
[build] [ 51%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_printf.c.obj
[build] [ 52%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_lseek.c.obj
[build] [ 53%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_main.c.obj
[build] [ 54%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_malloc_lock.c.obj
[build] [ 55%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_open.c.obj
[build] [ 56%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_printf.c.obj
[build] [ 57%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_putstr.c.obj
[build] [ 58%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_putchar.c.obj
[build] [ 59%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_putcharbuf.c.obj
[build] [ 60%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_read.c.obj
[build] [ 61%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_remap_cached.c.obj
[build] [ 62%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_release_fd.c.obj
[build] [ 63%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_remap_uncached.c.obj
[build] [ 64%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_rename.c.obj
[build] [ 66%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_sbrk.c.obj
[build] [ 65%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_settod.c.obj
[build] [ 67%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_stat.c.obj
[build] [ 68%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_tick.c.obj
[build] [ 70%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_times.c.obj
[build] [ 70%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_tls.c.obj
[build] [ 71%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_uncached_free.c.obj
[build] [ 72%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_uncached_malloc.c.obj
[build] [ 73%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_unlink.c.obj
[build] [ 74%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_usleep.c.obj
[build] [ 75%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_vic_isr_wrapper.c.obj
[build] [ 76%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_wait.c.obj
[build] [ 77%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_fpga_api_cmn_dfl.c.obj
[build] [ 78%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_write.c.obj
[build] [ 79%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_fpga_api_cmn_inf.c.obj
[build] [ 80%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_fpga_api_cmn_msg.c.obj
[build] [ 81%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_fpga_api_niosv.c.obj
[build] [ 82%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_fpga_platform_api_niosv.c.obj
[build] [ 83%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/intel_niosv_irq.c.obj
[build] [ 84%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/HAL/src/mtimer.c.obj
[build] [ 85%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/alt_sys_init.c.obj
[build] [ 86%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_jtag_uart_fd.c.obj
[build] [ 87%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_jtag_uart_init.c.obj
[build] [ 88%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_jtag_uart_ioctl.c.obj
[build] [ 89%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_jtag_uart_read.c.obj
[build] [ 90%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_jtag_uart_write.c.obj
[build] [ 91%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_sysid_qsys.c.obj
[build] [ 92%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_timer_sc.c.obj
[build] [ 94%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_timer_ts.c.obj
[build] [ 94%] Building C object hal_bsp/CMakeFiles/hal2_bsp.dir/drivers/src/altera_avalon_timer_vars.c.obj
[build] [ 95%] Linking C static library libhal2_bsp.a
[build] [ 95%] Built target hal2_bsp
[build] [ 95%] Building C object CMakeFiles/app.elf.dir/hello_world.c.obj
[build] [ 96%] Linking C executable app.elf
[build] C:/altera_standard/25.1std/riscfree/toolchain/riscv32-unknown-elf/bin/../lib/gcc/riscv32-unknown-elf/13.2.0/../../../../riscv32-unknown-elf/bin/ld.exe: address 0x4019500 of app.elf section `.bss' is not within region `onchip_memory2'
[build] collect2.exe: error: ld returned 1 exit status
[build] make[2]: *** [CMakeFiles/app.elf.dir/build.make:101: app.elf] Error 1
[build] make[1]: *** [CMakeFiles/Makefile2:118: CMakeFiles/app.elf.dir/all] Error 2
[build] make: *** [Makefile:91: all] Error 2
[proc] La commande « C:\altera_standard\25.1std\riscfree\build_tools\cmake\bin\cmake.exe --build c:/Users/tanguy-e/Downloads/test/software/app/build --config Debug --target all -j 8 -- » s’est arrêtée avec le code 2.
[driver] Build terminée : 00:00:12.693
[build] La build s'est achevée avec le code de sortie 2
Hi ETang2
