15 years agoSdram access in HDL and Nios II
Hi I'm fairly new to FPGA programming. I would like to use the onboard sdram memory of my DE2-70 board to pass data between c++ software, running on a Nios II cpu and a verilog component. W...
15 years ago@ Zwok
Could you please help me in this .. How did you write the pixels from the Nios II C code into the SDRAM? What C code did you use? Thanks
