15 years agoSdram access in HDL and Nios II
Hi I'm fairly new to FPGA programming. I would like to use the onboard sdram memory of my DE2-70 board to pass data between c++ software, running on a Nios II cpu and a verilog component. W...
15 years agoIf you only have 48x112 bytes of image data, it is probably easier to use dual-ported on-chip memory inside the vhdl component and write directly to it from your C code. That way you only have to write the simpler Avalon slave interface.
