21 years agoscheduling policy
We're running uClinux based on linux version 2.6.x under the Nios II IDE v1.0.0 build 393. In experimenting with POSIX threads, I've been attempting to activate timeslicing for an app...
21 years agoThanks, wentao, for the suggested code fragment.
The call to sched_setscheduler() successfully changed the scheduling policy without returning an error. I had tried something more like this:struct sched_param schp;
sched_getparam(getpid(), &schp);
schp.sched_priority = sched_get_priority_max(SCHED_RR);
if (sched_setscheduler(getpid(), SCHED_RR, &schp) != 0) {
perror("sched_setscheduler");
exit(1);
} Apparently, one needs to pass the root process ID of 0 in order to change the policy. Whatever, a subsequent call to sched_getparam passing it the calling process returns the changed schedule policy value, and a subsequent sched_setparam call with getpid() also works, so there it is. However, I'm not sure changing the policy did anything: My test case, minus the# includes and various queries and printf() calls, is: static int done;
void* threaddie(void* arg)
int i;
char c = *((char*) arg);
for(i = 0; i < 20; i++) {
putchar(c);
done++;
pthread_exit(NULL);
return NULL;
int main(int argc, char** argv)
pthread_t t1, t2, t3, t4;
char c1 = '1';
char c2 = '2';
char c3 = '3';
char c4 = '4';
int policy;
policy = SCHED_RR;
memset(&schp, 0, sizeof(schp));
schp.sched_priority = sched_get_priority_min(policy);
if (sched_setscheduler(0, policy, &schp) != 0) {
exit(1);
done = 0;
pthread_create(&t1, NULL, threaddie, (void*) &c1);
pthread_create(&t2, NULL, threaddie, (void*) &c2);
pthread_create(&t3, NULL, threaddie, (void*) &c3);
pthread_create(&t4, NULL, threaddie, (void*) &c4);
while (done < 4) {
sched_yield();
return 0; The output from this test case, regardless of whether policy is set to SCHED_RR, SCHED_FIFO, or SCHED_OTHER, is: 11111111111111111111222222222222222222223333333333333333333344444444444444444444 ...so linux is not preempting the first thread to run the second, and so on, which indicates to me that the scheduling policy change didn't work. Increasing the number of iterations just increases the number of 1's in a row etc. Inserting some busywork code (for example, declaring int j, then inserting j = i * 2 in the loop after the putchar) also has no effect. If I insert a call to sched_yield() after the putchar, I get: (for SCHED_RR) 11121212123123123412341234123412341234123412341234123412341234123423423434343444 (SCHED_OTHER is slightly different) 12123412341234123412341234123412341234123412341234123412341234123412341234123434 If I replace the sched_yield() call with usleep(1), I get (regardless of policy): 12341234123412341234123412341234123412341234123412341234123412341234123412341234 Maybe there's something I'm not understanding about pre-emption. Is it possible that the scheduler isn't being called because the first thread is in the kernel with interrupts off (because of the putchar call) every time the interval timer goes off? Seems far fetched to me. At any rate, I'm further along than I was, so I appreciate the suggestion.
