10 years agoSampling Multiple Channels with the ADC at The Same Time
Hello everyone, I am currently trying to sample two differential signals at the same time and I was wondering if there is an easy way to do this in the c code. I can currently sample one chann...
10 years ago --- Quote Start --- I did some more research. That statement does not mean that there are 8 ADCS. There are 8 input pins that are connected via a mux which then goes into a single ADC. I am just going to write some code to ping between two channels and see how that works. --- Quote End --- ok with such slow ADC it is possible to mux any number of inputs so one adc is time shared between them like a queue. As such what matters to you should be how read the relevant channel in the queue. This info should be available to you from vendor.
