15 years agoS29AL008J Issue: Flash is not working
I have found few or no information about the compliant of the following Spansion flash memory model: S29AL008J. Have any one already used it ? I am using exactly the model S29AL008J70TFI01. It...
15 years ago@Rosetto, thanks for answer. Didn't look at weldings with microscope.
@Metalous : You have to create yourself the override file and you need the datasheet. It is explained in altera flash programmer user guide (with an example). Not very obvious! To test flash, the flash must be free memory (no program, no assigned to reset vector...) Look at the name you gave to the flash.
