20 years ago
R/W Filesystem?
I'm currently running the stock FS, built following the instructions in the Getting Started manual.
Is there any quick way to make this FS read/write? Changing the kernel command line string to 'root=/dev/mtdblock0 rw' didn't work.
If this is possible, great -- my second problem is then how to 'save' FS changes back to flash (i.e. surviving a reboot/power cycle).
If not, what do I need to do this?
All I'd really like to do is be able to update config files and my userland apps via FTP instead of the oftentimes tedious (not to mention expensive) procedure of needing a ($$)Blaster cable and flashing the new FS image everytime I change a line of code.
Ryan
Quantapoint
    Hi!
    If changed the altera.c for my on memory partition in this way:
        .name =   "part1",
        .size =   0x100000,
        .offset = 0x700000,
        .name =   "romfs/jffs2",
        .size =   0x500000,
        .offset = 0x200000,
        .name =   "loader/kernel",
        .size =   0x200000,
        .offset = 0,
        .name =   "User configuration",
        .size =   0x400000,
        .offset = 0x800000,
        .name =   "safe configuration",
        .size =   0x400000,
        .offset = 0xc00000,
        .mask_flags = MTD_WRITEABLE,  /* force read-only */
    Then if have build the kernel again and uploaded it.
    But when I try to start Linux it's stopped with kernel panic error:
    using altera ndk partition definition
    creating 5 mtd partitions on "altera ndk flash (amd)":
    0x00700000-0x00800000 : "part1"
    0x00200000-0x00700000 : "romfs/jffs2"
    0x00000000-0x00200000 : "loader/kernel"
    0x00800000-0x00c00000 : "user configuration"
    0x00c00000-0x01000000 : "safe configuration"
    net: registered protocol family 2
    ip: routing cache hash table of 512 buckets, 4kbytes
    tcp established hash table entries: 1024 (order: 1, 8192 bytes)
    tcp bind hash table entries: 1024 (order: 0, 4096 bytes)
    tcp: hash tables configured (established 1024 bind 1024)
    net: registered protocol family 1
    net: registered protocol family 17
    kernel panic - not syncing: vfs: unable to mount root fs on unknown-block(31,0)
    What's going wrong?
    Bye, Lothar.
    Hi!
    I have changed the order of the partitions in altera.c by putting my own partition at the end of the list:
    #ifdef CONFIG_ALTERA_STRATIX_II
        .size =   0x500000,
        .offset = 0x200000,
        .size =   0x200000,
        .offset = 0,
        .size =   0x400000,
        .offset = 0x800000,
        .size =   0x400000,
        .offset = 0xc00000,
        .name =   "part1",
        .size =   0x100000,
        .offset = 0x700000,
    and so it works.
    Bye, Lothar.
    Hi friends!
    I've make a new partition as you can see by this start sequence:
    and by the following command output:
    ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~# cat proc/partitions
    major minor # blocks name
    31 0 5120 mtdblock0
    31 1 2048 mtdblock1
    31 2 4096 mtdblock2
    31 3 4096 mtdblock3
    31 4 1024 mtdblock4#
    For this partition I've generated a block device directly by "@mtdblock4,b,31,4" in the filesystem which I've uploaded.
    When I try to erase the content of partition part1 alias mtdblock4 by the following program the board reboot.
    #include <stdio.h># include "system.h"# include "sys/alt_flash.h"
    int main(int argc, char* argv)
      alt_flash_fd* flash;
      int i;
      printf("alt_flash_open_dev(&#39;../dev/mtdblock4&#39;)");
      flash=alt_flash_open_dev("../dev/mtdblock4");
      for (i=0x700000;i<0x800000;i=i+0x10000)
       printf("Erase %08x\n",i);
       alt_erase_flash_block(flash,i,0x10000);
      return 0;
    Why does the board reboot by this program?
    Bye, Lothar.
