20 years agorunning sw in SDRAM
Hello, I want to use SDRAM for a small set of functions, toghether with big chunks of data. The rest of the software runs from SRAM. I verfied the correct working of the SDRAM, the instruc...
20 years ago --- Quote Start --- originally posted by victors@Jan 3 2006, 01:57 PM i use sdram for most of my projects and have never had a problem. looks like normal memory.
a few things to check: maybe you have a screw-up with the stack or something.
* compile a program to run only from sdram. if that works then you might have screw-up pointers. --- Quote End --- I tried also a small program running only from SDRAM, no luck. <div class='quotetop'>QUOTE </div> --- Quote Start --- * How have you compiled the code? Most of time the functions are not relocatable. Have you compiled the code for that specific location in SDRAM or just copied it there?[/b] --- Quote End --- I added a section in the linkerscript and then used the __attribute((.section(".sdram"))) on the function. I verified in on object dump, and it seems to be ok. <div class='quotetop'>QUOTE </div> --- Quote Start --- *Where are the local variables stored?[/b] --- Quote End --- in SRAM, only one global integer to test. <div class='quotetop'>QUOTE </div> --- Quote Start --- *When the function returns where does it return to?[/b] --- Quote End --- I hope to the place where it was called from. Here's the small test function :
volatile int ga = 0;
void TestSDRam() __attribute__ ((section (".sdram")));
void TestSDRam()
__asm__("NOP");
__asm__("NOP");
__asm__("NOP");
__asm__("NOP");
ga++;
} This function gets compiled to : Disassembly of section .sdram:
01000000 <_Z9TestSDRamv>:
1000000: 0001883a nop
1000004: 0001883a nop
1000008: 0001883a nop
100000c: 0001883a nop
1000010: 00c00534 movhi r3,20
1000014: 18c6d404 addi r3,r3,6992
1000018: 18800037 ldwio r2,0(r3)
100001c: 10800044 addi r2,r2,1
1000020: 18800035 stwio r2,0(r3)
1000024: f800283a ret This function is called from somewhere else in the sw, and I print out the memory contents before the call, so I can verify the code is still there : void foo()
volatile int* a = (int*) na_SDRAM;
for (int k = 0; k < 40; k++)
printf("%08x : %08x \r", a, *a);
a++;
TestSDRam();
printf("ga : %d\r", ga);
} The result : 01000000 : 0001883a
01000004 : 0001883a
01000008 : 0001883a
0100000c : 0001883a
01000010 : 00c00534
01000014 : 18c6d404
01000018 : 18800037
0100001c : 10800044
01000020 : 18800035
01000024 : f800283a
01000028 : 32463032
0100002c : 31303343
01000030 : 32423030
01000034 : 31303443
01000038 : 34303030
0100003c : 46464245
01000040 : 41374544
01000044 : 31333033
01000048 : 36423030
0100004c : 33530a0d
01000050 : 30303531
01000054 : 30343030
01000058 : 34303033
0100005c : 46374646
01000060 : 35314645
01000064 : 30343130
01000068 : 35314644
0100006c : 30303030
01000070 : 35314544
01000074 : 30384630
01000078 : 35363844
0100007c : 33530a0d
01000080 : 30303531
** START BOOTLOADER ** The processor starts again at its reset address. Yesterday, I tried the same, and the processor didn't restart, the only change was that I didn't use the -G0 compiler option to get rid of the global pointer. Still the integer 'ga' was nopt modified. With the use of the global pointer, I have this disassembled code : 01000000 <_Z9TestSDRamv>:
1000010: d0a00337 ldwio r2,-32756(gp)
1000014: 10800044 addi r2,r2,1
1000018: d0a00335 stwio r2,-32756(gp)
100001c: f800283a ret The only difference here seems to be the use of register r3. I can not understand why this changes the effect on calling the function. Stefaan
