12 years agoRunning separate C code on separate core in NIOS Multi-core system
I have done projects on NIOS II core for single processor system. Now, I need to learn and implement a multi-core system. I have very basic doubts for a multi-core system: 1. If I have two independent cores. How to run separate c codes on that two core ?? And that two codes should start simultaneously. Is it compulsory to make one core as Master to start the another core?? 2. If I have dependent cores, How to communicate between two cores?? While communicating with a slave peripheral, we generally knows the address for diff registers in slave device and use to specify that address during Avalon MM interface. But if i want to send some data from one core to another, what are all the option and how ?? Please Suggest. -Anuj11 Replies
If you google that error, you get this knowledge base article which may be relevant to you:
http://www.altera.com/support/kdb/solutions/rd10082010_852.html
