8 years agoRunning a Program from SDRAM instead of OCRAM
Hello, I'm currently trying to run code I had previously run on the OCRAM onto the SDRAM. I was using the Bare Metal User Guide(https://www.altera.com/documentation/lro1424280108409.html) to do...
MCOUNSELL
7 years agoHi,
I feel your pain! Just found your question while searching for "! General error on memory or register access." .... I have the same issue. I have the feeling that my preloader is not working correctly or is not being loaded by bootROM correctly for some reason ..... but I'm in the dark. Zero support from Alter/Intel........ the docs and examples are good - in perfect world when stuff just works... if they don't .... there's very little way to find out what'sup.
Mike
AJama4
7 years agoSame problem I am facing, and I have tried by doing lots and lots of alterations but it doesn't work. The Intel Guys are non-responsive. This is just one example. There are few places where when one when get stucks, no one is there to answer/solve the query.
