ROM initialisation
I created a SOPC-builder module with an on-chip ROM component. This ROM should be instantiated with the content of on_chip_rom.hex, that is in the Quartus directory and contains just 0s. I want another content and wrote the following lines in my c-file (totally 512 bytes): static const unsigned int cardbus_content[] __attribute__ ((section (".on_chip_rom"))) = {0x12345678, 0x87654321, 0x22222222, 0x33333333, 0xf70000ff, 0xffffccff, ...}; The IDE is also rewriting the on_chip_rom.hex file 8as expected) during compilation but with 0's and not my values. The section in the .objdump file looks like this: 8 .on_chip_rom 00000000 00801600 00801600 0000ef58 2**0 CONTENTS Where is my mistake? How do I initialize memories with the IDE? Best Regards, damc P.S. Simply creating the .hex file as it was possible with Nios1 isn't possible anymore, because the IDE is overwriting this file with 0's on every compilation.7 Replies
You have to make sure the boot address in SOPC builder is that specific onchip memory. That hex file is probably wiped clean on purpose (since you are not targetting it, the compiler gives you a clean slate).
In the system library select that onchip memory, compile your software, then compile your hardware in quartus. Another thing to keep in mind is depending on the memory you selected (512, M4k, MRAM) you may have different options available (or lack of options). If my memory is correct, to have pre-populated onchip RAM you can't use MRAM (but I think it's ok with onchip ROM in MRAM but don't quote me on that one). If that's an issue for you take a look at the Tri memory document up on the Altera site. - Altera_Forum
I don't want to boot out of this memory.
It contains static stuff like a serial number, version number and such things and should be only read out by the Nios on demand of the user. Therefore I tried the construct above but it seems not to work. - Altera_Forum
Hi damc,
> The section in the .objdump file looks like this: > 8 .on_chip_rom 00000000 00801600 00801600 0000ef58 2**0 > CONTENTS This indicates that section .on_chip_rom has a length of zero. Better check your linker command file. If you don't reference cardbus_content anywhere in your code, the linker might be tossing it into the bit bucket ... so you'll need to either wrap a KEEP around your .on_chip_rom input section(s) ... or add some dummy code that references cardbus_content. By default, I don't believe the linker command file in the syslib wraps on-chip memory input sections with a KEEP. Regards, --Scott - Altera_Forum
Hi damc,
my design uses intern ROM to store a 'parking code' while system RAM is overwritten. I also set up an array with __attribute__((.section)). But if you never use this code or data in another module, it is optimized away and preset with zeros. Make a dummy call in any module to this section or anything else that signals the compiler: this data is used. After your hex-file is created, you must compile your cpu with SOPC builder to implement this data in your design. Mike edit: (... same tip at same time) - Altera_Forum
Sorry notice that you wanted just a ROM out of it. In the past I would just set up my own hex file and drop that into the hardware folder. The only problem with doing that is it will get overwritten by the IDE. The previous two tips sound like a good solution and probably your best option.
Hi smcnutt, MiR,
you have had right, after I inserted a dummy call to that array the on_chip_rom.hex file is now filled with the correct data. Thank you very much!!!! Hi BadOmen, yes in the past everything was much easier and more simple .... Thanks again, damc - Altera_Forum
Haha, I don't know if what I used to do was more simple (I would create my mif file in Excel and have to do weird character delimiting a pray they were properly formatted).
Good to hear the other solutions worked
