Riscfree compilation error with message ".bss not within region onchip_mem"
I have tried with the Rsicfree version that you indicated but seems that this version doesn't support the direct import of the NiosV Cmake project. I will need to ask if there is a way to do it from Riscfree, but my guess is that you will need to build the application from the NiosV shell.
- Thierry291 year ago
Hi Rolando,
an unofficial tutorial explains how to import a Nios V project into Riscfree for versions that do not yet offer the automatic import option (https://malt.zendesk.com/hc/en-us/articles/9280647796761-Nios-V-Project-Development-Procedure-Using-Ashling-RiscFree-IDE , part 4.5.1). I was not able to follow this procedure, it may not exactly match the version I am using.
I would use the last version of Riscfree but it seems it has a bug : https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/RiscFree-v25-1-1-no-longer-finds-BSP-and-compiler-headers-files/m-p/1676846#M53545 without a clear workaround.
Thierry
- RolandoS_Altera1 year ago
Hi Thierry
I was able to build your application from Riscfree using the instructions provided in the Macnica application note. I also looked in to the case that reports the issue in Riscfree and I agree that the workaround is not clear. I am asking internally to see if the person who was supporting that case is able to provide the workaround.
Rolando
Hi Rolando,
it is good news that you were able to build the application using the Macnica application note. I tried to do the same thing and can detail where our paths seem to diverge.
I follow very scrupulously the tutorial up to the end of 4.5.1. The only difference is that I am using Riscfree v23.4.1 instead of v22.2.2. Everything seems normal until the "Finish" command to create the project in Risfree. Warnings are displayed in "Problems" tab with the informations below (by category):
Description:
File '/app/build/Debug/compile_commands.json' was not created in the build. Your workbench will not know all include paths and preprocessor defines.Resource:
appLocation:
de.marw.cmake.cdt.language.settings.providers.CompileCommandsJsonParserType:
CMAKE_EXPORT_COMPILE_COMMANDS Parser ProblemDespite these warnings, I tried to build the application ("Build Project" command). As you can see below, the project is build (with no errors) with gmake not cmake. I do not understand why.
08:58:03 **** Build of configuration Debug for project app ****
"C:\\PROGRA~1\\MATLAB\\R2020b\\bin\\win64\\gmake.exe" -j all
[ 1%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_macro.S.obj
[ 3%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/machine_trap.S.obj
[ 96%] Building C object CMakeFiles/hello.elf.dir/hello.c.obj
[ 97%] Linking C executable hello.elf
[ 97%] Built target hello.elf
[100%] Creating hello.elf.objdump.
[100%] Reporting memory available for stack + heap in hello.elf.
hello.elf
* 125.44 KB - Program size (code + initialized data).
* 23.36 KB - Free for stack + heap.
[100%] Built target niosv-stack-report
[100%] Built target create-objdump
08:58:10 Build Finished. 0 errors, 0 warnings. (took 7s.9ms)
I join the app and bsp. You might want to check if the behavior is the same in your case.
Thank,
Thierry
