15 years agoRequires DSP kit which is Linux & Android compatible
I need to have DSP kit having following specs. 1GB Ram(Max) Ports: 485 * 2 & 422 Ethernet * 2 Port :232* 2 Serial to USB Converter (1 MB Support) Battery Supported Touch Screen Co...
15 years agoI don't know any Altera kit that can run Android. You'll probably have to try and put an ARM but it won't be an easy task. You'll probably have better chance with a hardcore ARM board instead of a kit from Altera.
