MHahn4's avatar
MHahn4
7 years ago
Required $SOPC_KIT_NIOS2 Environmental Variable is not set
I'm trying to get the Nios II Eclipse toolchain to work on a Windows 10 machine. But the New Project wizard (File -> New -> Nios II Application and BSP from Template) does fail with the error:
Executing: wsl ./create-this-app --no-make (C:\some\directory\projectname\qsys\software\test_software)
Required $SOPC_KIT_NIOS2 Environmental Variable is not set!
I've set the SOPC_KIT_NIOS2 variable to "C:\intelFPGA_pro\19.2\nios2eds" both on Windows and the WSL Linux (Ubuntu 18.04 LTS) and also in the Eclipse settings (C/C++ -> Build -> Environment). But the error still occurs.
Did I miss something?
Or is there a way to set the Nios II toolchain to use Cygwin instead of wsl?
Edit:
I could narrow the problem to the wsl command:
bash -c "echo $SOPC_KIT_NIOS2"
outputs the environment variable correctly, but
wsl echo $SOPC_KIT_NIOS2
can't find it. Sadly the generated scripts use the wsl command...
How can this be resolved?
  • Found the answer:
    Created a new environment variable in Windows:
    Value: SOPC_KIT_NIOS2/p
    After restarting Eclipse and Quartus it worked.
  • MHahn4's avatar
    MHahn4
    Found the answer:
    • malcolm_locke's avatar
      malcolm_locke
      Great :). I have no idea how you worked this out but it worked for me
