15 years agoReduce size of hex file to fit into on chip memory
Hi hex file produced by Nios II IDE for my application is more than the onchip memory that I have. I want to reduce the size of that. I am using the blank project in Nios II IDE and adding my .pt...
15 years agoHex files are in a text format: you can read them with any editor like Windows Notepad. Each couple of bytes in the files, encodes one single byte in memory.
Then, your 240kB hex files describes a maximum of 120kB of memory bytes. But since every line of hex file also contains information about memory address, line length and check sum, I think you'll get exactly 100kb. Go here for detailed information: http://en.wikipedia.org/wiki/intel_hex
