15 years agoReduce size of hex file to fit into on chip memory
Hi hex file produced by Nios II IDE for my application is more than the onchip memory that I have. I want to reduce the size of that. I am using the blank project in Nios II IDE and adding my .pt...
15 years agoit is needed in your design that program memory must be "onchip memory" only? Because as you said you followed all suggestions and then also u are not able to get rid of your problem.
Because if your system is big,though u will try all,you will not able to fit ur sytem into the onchip memory. so you integrate another memory in your sytem and make them program memory in NIOS IDE.
