10 years agorebuilt u-boot does not recognize USB storage devices
Hi I have an Altera SoCKit from Terasic. They provide a pre-built image that includes the SPL and u-boot.img (i.e. the contents of the "a2" partition). I can use it to access storage devices (...
10 years agoAlthough the mix and match might work, it's not advisable as this combination is untested from time to time.
I believe you can use the latest SPL which is the same as U-Boot. But note one thing is that the new SPL is expecting the U-Boot in raw partition (bs=512 seek=2560) instead of FAT filesystem. I am working on the patch to fix FAT enablement in SPL as the size too large to fix 64kB. Coincidentally I managed to grab a Kingston pendrive. It works well with the 2013.01.01 version as below U-Boot SPL 2013.01.01-00132-gd141e21 (Dec 28 2015 - 13:53:18) BOARD : Altera SOCFPGA Cyclone V Board CLOCK: EOSC1 clock 25000 KHz CLOCK: EOSC2 clock 0 KHz CLOCK: F2S_SDR_REF clock 0 KHz CLOCK: F2S_PER_REF clock 0 KHz CLOCK: MPU clock 925 MHz CLOCK: DDR clock 400 MHz CLOCK: UART clock 100000 KHz CLOCK: MMC clock 50000 KHz CLOCK: QSPI clock 370000 KHz RESET: COLD INFO : Watchdog enabled SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED SDRAM: 1024 MiB ALTERA DWMMC: 0 reading u-boot.img reading u-boot.img U-Boot 2013.01.01-00132-gd141e21 (Dec 28 2015 - 13:53:18) CPU : Altera SOCFPGA Platform BOARD : Altera SOCFPGA Cyclone V Board I2C: ready DRAM: 1 GiB MMC: ALTERA DWMMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: mii0 Hit any key to stop autoboot: 0 SOCFPGA_CYCLONE5# usb reset (Re)start USB... USB0: Core Release: 2.93a scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found SOCFPGA_CYCLONE5# usb info 1: Hub, USB Revision 1.10 - DWC OTG RootHub - Class: Hub - PacketSize: 8 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 0.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Setting 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms 2: Mass Storage, USB Revision 2.0 - Kingston DataTraveler 2.0 5B670D009F2D - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x13fe Product 0x1a00 Version 1.0 Configuration: 1 - Interfaces: 1 Bus Powered 200mA Interface: 0 - Alternate Setting 0, Endpoints: 2 - Class Mass Storage, Transp. SCSI, Bulk only - Endpoint 1 In Bulk MaxPacket 512 - Endpoint 2 Out Bulk MaxPacket 512 SOCFPGA_CYCLONE5#
