10 years agorebuilt u-boot does not recognize USB storage devices
Hi I have an Altera SoCKit from Terasic. They provide a pre-built image that includes the SPL and u-boot.img (i.e. the contents of the "a2" partition). I can use it to access storage devices (...
10 years ago --- Quote Start --- You can try to use latest U-Boot at http://git.denx.de/?p=u-boot/u-boot-socfpga.git;a=summary Wonder which USB stick that you are using? Can you try out to disable the dcache and check whether it works? --- Quote End --- I tried https://github.com/altera-opensource/u-boot-socfpga, branch: master, tag: v2015.10 which seemed promising as it included Terasic board support (by Marek Vasut). The resulting image did not work (hung just after SPL executed). I am still using the SPL from the pre-made 2013.01.01 build - not sure if that matters (e.g. do these need to be replaced as a set). There a few later versions in the git repo past v2015.10, but I would have expected this one to at least boot. I'm getting further from a solution... When I restore my 2013.01.01 build I will try disabling dcache (via# define CONFIG_SYS_DCACHE_OFF in socfpga_cyclone5.h). Thanks, --George BTW - with the pre-built image, I can read the USB stick just fine. Here is the info on it since you were curious: SOCFPGA_CYCLONE5# usb info 1: Mass Storage, USB Revision 2.0 - Kingston DataTraveler SE9 0014857749E5ECB0173000D3 - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x0930 Product 0x6545 Version 1.0 Configuration: 1 - Interfaces: 1 Bus Powered 200mA Interface: 0 - Alternate Setting 0, Endpoints: 2 - Class Mass Storage, Transp. SCSI, Bulk only - Endpoint 1 In Bulk MaxPacket 512 - Endpoint 2 Out Bulk MaxPacket 512
