20 years agoRebuilding library after changing hardware design
I am using the standard FPGA design from the Nios II kit and I have a working project with ecos. I want to add another PIO port to my design. After adding the new PIO port in SOPC builder and rebuild...
20 years ago --- Quote Start --- originally posted by snadden@May 5 2006, 03:27 PM i am using the standard fpga design from the nios ii kit and i have a working project with ecos. i want to add another pio port to my design. after adding the new pio port in sopc builder and rebuilding the fpga design in quartus, how do i rebuild ecos to give me access to the new pio port? i tried using the nios2config tool to clean and then rebuild my project, but this did not generate a new copy of install/cyg/hal/system.h in the folders under my ecos project.
i then made a new ecos configuration file in a new folder. when i built that library the system.h file which was generated contained references to the new pio port i had added. i don't want to have to start a new ecos project every time i tweak my hardware, is there a method to make nios2config regenerate the system.h file after changing the hardware design?
mike
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15080)
--- quote end ---
--- Quote End --- Just delete your folders like this foo_build, foo_install, foo_mlt and then you should regenerate Bulid Tree But I think you should try "Generate Bulid Tree" only. Try it!
