11 years agoReason still provode sd card utility as linux dd command can do the same ?
I a bit curious to ask around why we have multiple tools but they are actually doing the similar task? such as the SD card ulility and the dd command both also able to update the SD card partitions. ...
11 years ago --- Quote Start --- i can see the sd card utility feature not able to flash kernel or file system --- Quote End --- Hi, you don't need the sd card utility tool already if you are in linux operating system, especially for kernal adn fle system build, as the usage of the dd write command is more convenient already..
