15 years agoRead physical address
Hello, I'm trying to read address 0x0400000 (start address of avalon interface 32bits read) and the NIOS just stopped working, I can't read the entire memory block (0x0400000 - 0x040ffff or so...
15 years ago --- Quote Start --- wait a minute... setting the MSb to 1 makes you bypass the cache on Nios2, not doing magic on the handshakes. Are you sure the problem is solved? --- Quote End --- Yep, can you explain why I need to bypass the cache ?
