16 years agoread and write timings on avalon interface
Hello! I'm having some issues with the timings of read and write operations to my custom peripherals. I am using a Nios 2 processor a PIO peripheral for testing and my custom peripheral....
16 years agoAre you running code out out internal (tightly coupled M9K) memeory?
If you are running from anything else (via the i-cache) that could easily cause 'random' timings. If you avoid calls into libc, and sort out the fubar of main() v int_main() you should be able to get a very small object image. You also want to have all other data areas tightly coupled - exept for anything that has to be external (in which case the d-cache may also be pointless). Otherwise cycle times will not be deterministic. Also, you peripheral needs to expose a 32bit interface, otherwise there are likely to be multiple cycles - even for a byte access. The difference between writing zero and non-zero could well be in the object code, the non-zero value needs to be generated, the zero is in r0. 14 cycles sound more like the time for a sdram access - especially a full burst for a cache line. With no other avalon bus cycles, I believe the cpu will continue exection following the write until another avalon cycle is requested. Similarly it will continue after issuing a read until an instruction needs the value. A 'lateral thought' option is to use custom instructions to interface with the peripheral, not the Avalon bus .....
