Patrik78
3 years agoUART 16550 IP - Stick parity problem
in my company we're facing a problem while using UART 16550 IP in stick parity mode: on LSR register we set SP=1, EPS=1, PEN=1 in order to use MARK_PARITY.
While in transmission everything...
Patrik78
3 years agoHello Sheng,
we can't use break signal in our application, so we're forced to make the parity check work without the use of break.
Could you check other reasons why the PE is set receiving 0x55 with '0' as parity bit, and not set when receiving 0x57 with '0' as parity bit , assuming receiver is set to check parity MARK?
