GHelb
6 years agoSegmentation Violation - core dumped How to get around this error message? It happens every time I run eclipse-nios2
Using OpenJDK on ubuntu - versions 14, 16 & 18 - I get the error message "Segmentation Violation - Core Dumped" when trying to run 'eclipse-nios2' from Quartus - versions 17.1, 18.1.1, and 19.1.
GHelb
6 years agoIn another thread is was suggested that installing wsl would fix the problem. It does not fix the problem with Ubuntu 16.04
Please note that booting Ubuntu and running Ubuntu under Windows-10 WSL are different. Working in one does not mean that it will work in the other. And the goal should be to get it working in both.
What additional libraries need to be installed to use NIOS SDK 18.1.1 in Ubuntu 16.04?
