Broddo
1 year agoNIOSV/g with FPU: inconsistent calculation results
I'm using a NIOSV/g with FPU enabled in a MAX10 project. The project involves heavy use of float point calculations, hence the need for the FPU. I noticed some occasionally inconsistent results in th...
Mark_H_Intel1
1 year agoHi @Broddo
Just to let you know, we have found and fixed the issue. A patch is being prepared and is currently in internal testing.
Thank you very much for the example code, that helped us find the root cause very quickly.
Mark
