Hi @Broddo
Can you share your processor IP Parameter Editor settings?
And which Quartus version is your design based on?
Or, you can zip the design & attach it in your next reply.
Liang Yu
- Broddo1 year ago
Thanks for the reply @LYGOOI and apologies for the delay in getting back to you - I was on vacation.
To answer your questions: I'm using Quartus Lite 24.1 and I've pasted the CPU parameters below.
I've attached the test project that builds all of this. I'm running on a custom board (that was previously running a NIOS2 application with no issues). If you want to run it yourself, the only change you'll have to make is the location of the source clock.
For convenience, I've added a Makefile that will build the project and the software - you'll see for yourself.
Here are the CPU parameters
<module name="intel_niosv_g_0" kind="intel_niosv_g" version="4.0.0" enabled="1"> <parameter name="AUTO_CLK_CLOCK_DOMAIN" value="3" /> <parameter name="AUTO_CLK_RESET_DOMAIN" value="3" /> <parameter name="AUTO_DEVICE" value="10M50DAF484C8G" /> <parameter name="AUTO_DEVICE_SPEEDGRADE" value="8" /> <parameter name="Blind_Window_Period" value="1000" /> <parameter name="CLICenabledInterruptMode" value="0" /> <parameter name="CLICenabledShadowRegisterFiles" value="1" /> <parameter name="CUSTOM_OP" value="" /> <parameter name="Default_Timeout_Period" value="255" /> <parameter name="SUB_OP" value="" /> <parameter name="alignCLICVectorTable" value="8" /> <parameter name="basicInterruptMode" value="0" /> <parameter name="basicShadowRegisterFiles" value="0" /> <parameter name="clockFrequency" value="75000000" /> <parameter name="dataCacheSize" value="4096" /> <parameter name="dataSlaveMapParam"><![CDATA[<address-map><slave name='onchip_flash.data' start='0x0' end='0x160000' type='altera_onchip_flash.data' /><slave name='onchip_memory.s1' start='0x200000' end='0x214000' type='altera_avalon_onchip_memory2.s1' /><slave name='intel_niosv_g_0.dm_agent' start='0x220000' end='0x230000' type='intel_niosv_g.dm_agent' /><slave name='intel_niosv_g_0.timer_sw_agent' start='0x230000' end='0x230040' type='intel_niosv_g.timer_sw_agent' /><slave name='jtag_uart_0.avalon_jtag_slave' start='0x230040' end='0x230048' type='altera_avalon_jtag_uart.avalon_jtag_slave' /><slave name='onchip_flash.csr' start='0x230048' end='0x230050' type='altera_onchip_flash.csr' /></address-map>]]></parameter> <parameter name="deviceFamily" value="MAX 10" /> <parameter name="disableFsqrtFdiv" value="false" /> <parameter name="dtcm1Base" value="18874368" /> <parameter name="dtcm1InitFile" value="" /> <parameter name="dtcm1Size" value="0" /> <parameter name="dtcm2Base" value="0" /> <parameter name="dtcm2InitFile" value="" /> <parameter name="dtcm2Size" value="0" /> <parameter name="enableBranchPrediction" value="true" /> <parameter name="enableCLICInterruptEdgeTriggerConfig" value="false" /> <parameter name="enableCLICInterruptPolarityConfig" value="false" /> <parameter name="enableCLICSelectiveHardwareVectoring" value="false" /> <parameter name="enableCoreLevelInterruptController" value="false" /> <parameter name="enableDebug" value="true" /> <parameter name="enableDebugReset" value="true" /> <parameter name="enableECCFull" value="false" /> <parameter name="enableECCLite" value="false" /> <parameter name="enableFPU" value="true" /> <parameter name="enableLockstep" value="false" /> <parameter name="enableLockstepExtRst" value="false" /> <parameter name="enableMulDiv" value="true" /> <parameter name="funct3" value="" /> <parameter name="funct7_l" value="" /> <parameter name="funct7_u" value="" /> <parameter name="hartId" value="0" /> <parameter name="instCacheSize" value="4096" /> <parameter name="instSlaveMapParam"><![CDATA[<address-map><slave name='onchip_flash.data' start='0x0' end='0x160000' type='altera_onchip_flash.data' /><slave name='onchip_memory.s1' start='0x200000' end='0x214000' type='altera_avalon_onchip_memory2.s1' /><slave name='intel_niosv_g_0.dm_agent' start='0x220000' end='0x230000' type='intel_niosv_g.dm_agent' /></address-map>]]></parameter> <parameter name="itcm1Base" value="19922944" /> <parameter name="itcm1InitFile" value="" /> <parameter name="itcm1Size" value="0" /> <parameter name="itcm2Base" value="0" /> <parameter name="itcm2InitFile" value="" /> <parameter name="itcm2Size" value="0" /> <parameter name="mnemonic" value="" /> <parameter name="numCLICDebugTriggers" value="0" /> <parameter name="numCLICLevels" value="2" /> <parameter name="numCLICPlatformInterrupts" value="16" /> <parameter name="numCLICPriorities" value="8" /> <parameter name="opcode" value="" /> <parameter name="peripheralRegionABase" value="2293760" /> <parameter name="peripheralRegionASize" value="65536" /> <parameter name="peripheralRegionBBase" value="67108864" /> <parameter name="peripheralRegionBSize" value="2097152" /> <parameter name="resetOffset" value="0" /> <parameter name="resetSlave" value="onchip_flash.data" /> <parameter name="useResetReq" value="false" /> </module>
