EstebanV_Altera
8 months agoHello,
This is not usual behavior, the default shouldn't behave like this. Are you having prints into the terminal? If you remove such prints the programs continues?
Which Quartus version are you using? Which NIOSV version (G,C,M)?
Please provide as much details as possible so I can reproduce
~E.V.
prashant_gohel
8 months agoHi Esteban,
I am using Quartus 25.1 with NIOSV version M.
When the terminal is open, everything works fine, but if I close the terminal, the NIOSV gets stuck. Our requirement is that the NIOSV should run normally without needing the terminal to be open.
