Eclipse not starting from inside quartus 19.1
i have the same problem in linux mint.
From version 18, nios2-eclipse gives "segmentation fault" error.
any fix?
thanx
Sadly, Intel has not addressed these defects. Nothing to be found in any tool updates.
For version 18.x there are a number of things to try:
1) Install the WSL package.
2) Get a fresh copy of eclipse mars.2 and apply the NIOS changes
3) Write a shell script that sets the QUARTUS environment and starts eclipse.
4) Go back to version 17.x
In version 19.1 the Platform Designer is broken. No need for Build Tools if one can't make a platform.
I have pointed out that the NIOS additions to eclipse should be distributed as an install-able package. Installing by writing over a collection of files is not the right way to do it.
Even when it does start it doesn't work properly. Several eclipse commands error-abort when you try to use them.
Good Luck!
