dos2unix fails to change permissions when creating project from template
- 5 years ago
I also ran into this problem. I did some debugging and the problem is that the dos2unix command tries to change the UNIX filesystem permissions of the temporary file it creates; this fails for me in WSL.
You need to tell WSL that it should allow these kinds of operations on the filesystem. You can do this as follows:
- Start your Ubuntu 18.04 LTS prompt
- Create/edit a file '/etc/wsl.conf'
- Add the following to '/etc/wsl.conf':
[automount] options = "metadata" - Save the file.
- Reboot your computer.
I have no idea why this works for some people but not others, but this worked for me and fixed the dos2unix permissions error; at which points I was able to create the BSP and everything else in Nios II EDS worked fine.
It might also be important to know that I am using Quartus Prime Lite v20.1.0 Build 711, and it's installed in C:\intelFPGA_lite\20.1
I also followed the instructions here
to install eclipse in the nios2eds/bin directory
