19 years agoRC5.vhdl
Hi, I have a RC5 module from the web site :www.whitebream.com I work with cyclone :EP1C3T100C7 , the clk is 50Mhz, I changed the CLK_SYS in the module to 50M, but the RC5 module is not respondin...
19 years agoHi
The code of that core is quite short so I take a look before going to lunch http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif I assume that the instantiation is correct If you leave the constant CLKS4BIT unchanged... > -- Calculate the number of clock cycled in each RC5 bittime > -- (which is 1.778ms) > constant CLKS4BIT :integer := SYS_CLK / 562; ...the sampling rate will be 89kHz at 50.000.000Hz SYS_CLK. The accepted pulse width of incoming RC Bits is nearly 45us (about 22.000 Bits/s). A very high transfer value for a simple IR diode. What is the result of the simulation? What is the used source of RC pin? Hope, this give you a hint Greetings Jens
