15 years agoRandom reset in Nios II
Can someone tell me what can basically cause a software random reset in Nios II? Thanks. Carid
15 years agoYou must provide more information to identify the cause.
Did you observe any correlation with particular software code execution, i/o switching, interrupts, etc ? And first of all, are you sure about reset signal, power supply stability, external memory timings? Did you try to run a simple program, possibly using only onchip memory, and verified if you still have the random reset behaviour?
