16 years agoquestion on EPCS
Hi all, is it possible to put root file system (jffs2) on epcs??? Therefore you can have all in epcs (sof, kernel, rootfs)... Any help will be appreciated Carlo
16 years agoHi dwesterg,
thak you again...you are probably right...this is not the right way... How much room could be needed in your opinion...from nioswiki (2c35_cf example) I see: vmimage (http://www.nioswiki.com/@api/deki/files/466/=vmimage) 1401.9 kB rootfs.jffs2 (http://www.nioswiki.com/@api/deki/files/470/=rootfs.jffs2) 3.38 MB niosii_cycloneii_2c35_full_featured_epcs_boot.sof (http://www.nioswiki.com/@api/deki/files/502/=niosii_cycloneii_2c35_full_featured_epcs_boot.sof) 821.46 kB I don't know exactly how big is the application sw that will run on the board but...what size do you have in mind (could be ok for you)??? Carlo
