16 years agoquestion on EPCS
Hi all, is it possible to put root file system (jffs2) on epcs??? Therefore you can have all in epcs (sof, kernel, rootfs)... Any help will be appreciated Carlo
16 years agoyou just need to ensure that there are drivers for the SPI device, i believe this is documenting on the nios wiki. you will need to map out the flash device config.c, i believe there are examples of that as well. Not much room in a spi flash though.
