16 years agoQuestion on "associatedClock" property of Avalon Slave
I am looking at generating a custom block of VHDL code that ideally will be seamless integration into the SOPC builder system. As I am reading the Avalon spec, I see the description for the "associa...
16 years agoIt is a property of the component .tcl file. Here is the .tcl API: http://www.altera.com/literature/hb/qts/qts_qii54022.pdf
I write a lot of components and I always start by using component editor and then make manual changes to the .tcl file after if needed. This saves me a few hundred lines of .tcl coding. Everything you need to write the .tcl file from scratch is in the .tcl API documentation; however, I would highly recommend starting with component editor to save time and minimize coding mistakes. Before coding up the .tcl file I would check to make sure your IP has Avalon complaint interfaces. You can find the various interfaces and signals that belong to each in the Avalon spec: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
