Quartus Pro 22.4: nios2-terminal STDIO Errors
- 3 years ago
I have got some news back from the engineering team where this fix will be schedule in future Quartus releases and there will be no fix for the current 22.4 version.
Hope this clarify your doubts. Let me know if you need any further clarification from my end.
Thank you.
Kelly
I have similar behaviour with 22.1std. Can this be caused by other issues such as a mis-match in fifo sizes. I get several connectivity issues with the jtag uart or is this the same issue with the tools?
; Port Connectivity Checks: "top:example|jtag_uart:u_jtag_uart|jtag_uart_jtag_uart_0:jtag_uart_0|alt_jtag_atlantic:jtag_uart_jtag_uart_0_alt_jtag_atlantic" ;
; Port ; Type ; Severity ; Details ;
; raw_tck ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; tdi ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; jtag_state_rti ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; usr1 ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; clr ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; ena ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; ir_in ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; tdo ; Output ; Warning ; Declared by entity but not connected by instance. Logic that only feeds a dangling port will be removed. ;
; ir_out ; Output ; Warning ; Declared by entity but not connected by instance. Logic that only feeds a dangling port will be removed. ;
; jtag_state_cdr ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; jtag_state_sdr ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
; jtag_state_udr ; Input ; Warning ; Declared by entity but not connected by instance. If a default value exists, it will be used. Otherwise, the port will be connected to GND. ;
