Quartus 19.1 NIOS II ED error: Makefile:1012: recipe for target '***.elf' failed
- 6 years ago
Hi!
The problem is solved, due to help of russian Intel distributor's engineering support. Thanks to Roman!
He pointed me to two things:
- need of dividing workspace project and source software directories. It must be different directories inside common project directory.
- use "New' - "NIOS II Application and Bsp from template" for generaion of new project structure. When I was generating new BSP, I used "New" - "NIOS II Board support package" and got such strange error:
Executing: wsl;nios2-bsp hal . ../../qsys_system.sopcinfo
--cpu-name nios2_gen2_0
(D:\Temp\axie_system_controller_restored\software\qsys_bsp)
/bin/bash: -c: line 0: syntax error near unexpected token `;'
/bin/bash: -c: line 0: `;nios2-bsp hal .
../../qsys_system.sopcinfo --cpu-name nios2_gen2_0'
Those advices helps me to build my project succesfuly in Quartus Prime Standart 19.1.
Hi! Thank you for support in my question.
I tried to run in wsl command prompt such command, as was recommended in support article:
make SOPCINFO_FILE=/mnt/d/Temp/axie_system_controller/qsys-system.sopcinfo --no-print-directory -C /mnt/d/Temp/axie_system_controller/Software/hal_bsp/
And I got the message: [BSP build complete]
So, it doesn' change the futher situation. After that, I got the same error.
Also, I added in the application make file such string:
SOPC_FILE := ../../qsys_system.sopcinfo
, and it doesn't helped me too.
I suppose, that the problem is in next tool:
nios2-elf-g++.exe -T'D:/Temp/axie_system_controller/Software/hal_bsp/linker.x' -msys-crt0='D:/Temp/axie_system_controller/Software/hal_bsp/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -LD:/Temp/axie_system_controller/Software/hal_bsp/ -Wl,-Map=qsys-app.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global -o qsys-app.elf obj/default/src/Main.o obj/default/src/ad9576.o obj/default/src/dac7568.o obj/default/src/stmpe1600.o -lm -msys-lib=m
, which must generate the .elf file, but it doesn't do it.
My be I should try the last version of Quartus Prime standart 20.1?
Best regards, Andrey
Hi!
