14 years agoQsys to custom HW interface
My FPGA design, including a Nios II, resides mostly inside the Qsys environment. However, I have some custom hardware elements outside of Qsys. I need to pass data and control signals between the tw...
14 years agoI am trying to connect Qsys to on-chip logic outside the Qsys environment and would like for the logic to appear to the Nios II SW as a wrtie-able location (such as RAM). In other words, when SW writes to this address it generates an external write signal along with the output data. I also need to read from a separate address.
I use this method to connect to external SRAM with no problem, but it does not seem to work with on-chip logic. The problem with a PIO is that it does not generate a write signal. I suppose I could create one as on of the PIO bits, but that's a lot of extra SW that I would rather do without.
