15 years agoQsys Problem with VIC
Always got this Warning: "WARNING: Tcl script C:\altera\11.0\ip\altera\altera_vectored_interrupt_controller\top\callbacks.tcl vic_0 c:/work/software/system_bsp drivers" error: expected integer but...
15 years agoThe problems you are seeing are due to the interrupt numbers not being populated in the system.h file. The workarounds are:
1) Use SOPC Builder until this issue is resolved 2) Manually key in the interrupt values into the system.h file 3) Switch to using the internal interrupt controller
