AlecBelousov's avatar
AlecBelousov
4 years ago
QSYS failed after upgrade to Quartus 21.1
Hello folks,
I have upgraded Quartus from very old version to 21.1 and i can not regenerate qsys module for DDR2 any more.
Error that i am getting is :
Error: s0: Error during execution of "{C:/intelfpga/21.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
I tried to search for solution, applied 0.01std patch but still have an issue.
Could you help me with it? I am inside Intel on local network.
Thank you,
OB
  • aikeu's avatar
    aikeu
    Hi AlecBelousov,
    I will look into this case and feedback to you soon.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi AlecBelousov,
    Is it possible that you try to use the Quartus 21.1 Linux version instead?
    I think the Linux version will work fine, as the Windows version got some issues when working with ddr related projects.
    Aik Eu
  • Hello Aik Eu,
    No, i cannot try Quartus 21.1 Linux version right now. Is there way to make Windows version to work?
    OB
  • aikeu's avatar
    aikeu
    Hi AlecBelousov,
    I noticed this issue only happened to Quartus Windows version.
    Quartus Linux version is working fine.
    There is a HSD filed for engineering. It is still in investigation stage and I dont think this issue will be solved in a short time.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi AlecBelousov,
    I will close this thread if there is no further question.
    Aik Eu
