11 years agoQsys error
HI , I tried to compile the DE2_115_Media_Computer example that targets DE2-115 board , while compiling Qsys files i am intimated about these errors : Error: System.External_Clocks.avalon_...
11 years agoI think it is fairly explanatory really.
To elaborate: "There is an 'Error' which is caused because in the system 'System' there is a component 'External_Clocks" which has an interface called 'avalon_clocks_slave' which is required to have an associated reset signal". So find the component named External_Clocks, which seems to be something you have made (is that correct?). On that component there is the interface mentioned. That is of type Avalon-MM Slave. As per the spec, Avalon-MM interfaces need a reset signal, but you haven't got one. So you need to add a reset signal and associate it with the Avalon-MM slave.
