qspi driver in NIOS bsp in Cyclone 10
Thank you!
After I generate sw hex file, I add it to Convert Programming File tool with sof file, and generate jic file and then burn it to flash with Quartus-->Tools--> Programmer tools. The programming is reported successfully.
when I generate hex file, I cannot understand those parameters, could you please help to explain them? or paste the link about the explanation of those parameters? For example, what is auto_create_rpd? why is it on? what is it for? what is rpd_little_endian? why is it on?
what is srec-forceS3? what is srec-len?
After the upper programming, I don't know whether the SW(C code ) could be run in NIOS(FPGA) as I cannot debug it from Eclipse. The reason is pasted in my upper post.
Please see the third picture in my upper post. Eclipse report: Verify failed between address 0x1000000 and 0x100FFFF.
I doubt there is a mistake in my operations. when I generate jic file, there is a map file generated. please the the map file below pasted.
My doubt is:
swimage start address in flash is: 0x00367F06, why did Eclipse very the address 0x1000000 and 0x100FFFF?
where and how can I tell Eclipse the sw image start address?
BLOCK START ADDRESS END ADDRESS
Page_0 0x00000000 0x00367F05
swimage.hex 0x00367F06 0x00380875
Configuration device: 10CL120Y
Configuration mode: Active Serial
Quad-Serial configuration device dummy clock cycle: 8
Notes:
- Data checksum for this conversion is 0x49A89CF7
- All the addresses in this file are byte addresses
