17 years agopushbutton interrup for ALTERA cyclonIII development board
pushbutton interrupts don´t work
My Quartus project is a download from http://www.nioswiki.com/exampledesigns/nio...20designexample (http://www.nioswiki.com/exampledesigns/niosii3c120designexample) 20090508a nios2 linux 3c120 125mhz.tar.gz was unpacked (I am not running linux though but uC-OSII with tools on Windows XP) My ALTERA Cyclone III Development Board be seen at http://www.altera.com/products/devkits/altera/kit-cyc3.html (http://www.altera.com/products/devkits/altera/kit-cyc3.html) I previously worked on the NEEK board and had the button interrupt working fine there for that board. I ported the code to My new project running on the Cyclone III Development Board and looked up the corresponding definitions in system.h My code now looks like this :#define BSP_BUTTON_ADDR USER_PB_PIO_4IN_BASE
volatile INT32S edge_capture; /* A variable to hold the value of the button pio edge capture register. */
void BSP_HandleButtonInterrupts(void* context, INT32U ID)
volatile int* edge_capture_ptr = (volatile int*) context;
// Store the value in the Button's edge capture register in *context.
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR);
switch(edge_capture) {
case 0x01:
registerPushButton(PUSHBUTTON_LEFT);
break;
case 0x02:
registerPushButton(PUSHBUTTON_RIGHT);
break;
case 0x04:
registerPushButton(PUSHBUTTON_UP);
break;
case 0x08:
registerPushButton(PUSHBUTTON_DOWN);
break;
default:
break;
// Reset the Button's edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR, 0);
void BSP_InitPushButtons(void)
// Recast the edge_capture pointer to match the alt_irq_register() function
// prototype.
void* edge_capture_ptr = (void*) &edge_capture;
// Enable all 4 button interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BSP_BUTTON_ADDR, 0xf);
// Reset the edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BSP_BUTTON_ADDR, 0x0);
// Register the interrupt handler.
alt_irq_register(USER_PB_PIO_4IN_IRQ, edge_capture_ptr, BSP_HandleButtonInterrupts );
} When I run the code It seems I get BSP_HandleButtonInterrupts() called continuously making the rest of the code freeze. When I step into BSP_HandleButtonInterrupts() , *edge_capture_ptr gets the value of 15. Any suggestions ??? Best regards1 Reply
fixed
Changed the content of Input Options for user_pb_pio_4in in SOPC builder to ... Synchronous capture [checked] Rising edge [selected] Generate IRQ [checked] Edge [selected] No other options was marked Made a complete rebuild of SOPC builder and Quartus New rebuild with create-this-app / create-this-bsp New import into Nios II IDE
